Oracle Procedure Execution
03-01-24 11:58 AM
I have a use case to execute Oracle procedure through Blue Prism tool, I am able to connect using Oracle MDA and select records from a table. Connection string is working fine. The issue is when I try to use the "Execute" action and call a procedure CALL test(1,'Mayank',' 1b str 35'); or use the EXEC command it gives a generic error "Operation is not valid due to the current state of the object." . I am not sure what is missing her .
Mayank Tiwari
0 REPLIES 0
