Please provide VBO for Notepad
Sri_Krishna_Cha
Hi-   I do not have Notepad VBO and need one. Unfortunately I am not able to find it in the VBO's tab. Please help
6 REPLIES 6
It will be quicker to make your own, it's just about the easiest object to create.
BastiaanBezemer
Also, if you just want to write a text file, use the VBO 'Utility - File Management' With as action 'Write Text File'
Sri_Krishna_Cha
Hi there- Yes I am aware of it. I am going through Foundation course and hence would like to follow the steps what they have instructed. It was mentioned to open the notepad VBO but they seems to be missing and hence requested in this forum. Does anyone have that by any chance so that I can reuse that.
I think you should contact support@blueprism.com or training@blueprism.com to inform them that the new training environements they are now using (recently switched to new training infastructure) is missing a Notepad VBO that is mentiond in the training documentation.
Sri_Krishna_Cha
Thank you all for the replies. I designed new VBO as I feel that would be the quicker solution
ManjunathN
Hi Chaitanya91 can you please share the VBO .
