Printing Automation
ShashiK_R
Hi All,
I have a business case of printing email attachments. Can anyone suggest me the best way to do this in blueprism without using the code stage?
Shashi K R
Shashi Kumar
vivek.kumar.goel
You can write a process, to OPEN OUTLOOK as an application, send ctrl+P and then ENTER 🙂
Vivek Goel
RPA Architect
Asia/Singapore
https://www.rpatools.com/
To be more specific, I need to print the attachment in the emails, and number of attachment and document extensions are dynamic.
Printing through Command prompt will not work as client network doesn't allow this print commands.
Any leads would be helpful.
Shashi K R
Shashi Kumar
Senior Software Engineer
Larsen and Toubro Infotech
Asia/Dili
Team,
After much analysis from the efficiency standpoint, the said requirement was developed and running successfully using the powershell commands. Just want to update the forum in case anyone comes across such use cases.
PS: you can also try sending the print commands in CMD as well.
Shashi K R
Shashi Kumar
Senior Consultant
PwC
Asia/Dili
