Process Session Not visible in Control Room Environment
20-07-22 09:53 AM
Hi All,
There is a process running in a resource. But can't able to See the Process Session after Login agent completion in Control Room Environment section.
How to enable the process view in environment.
Like the picture attached below only Login and Logout are visible.
Srihari
Srihari
20-07-22 10:41 AM
Hi Srihari,
Can you check if logout and Login_BOT are only the processes which are selected in process dropdown.
20-07-22 03:32 PM
Hi Neha,
I have checked , In the process dropdown all are selected.
Thanks ,
Srihari
Thanks ,
Srihari
