Process and Object library
16-07-18 11:07 PM
i see a very basic issue in my QA and Dev environment, we have a team of 20 developers, each developer creates few test process and few test objects, i am sure most of them stays in database as developers do not come back to deleted it.
It has become a huge list now, i would like to know what Blueprism suggest to handle this scenario ?
what should be archival and retention policies ? is there a way to handle it at admin level, like deleting process/object which was not used in a while ?
18-07-18 09:08 AM
You can delete a process/object if it has no logs associated with it. If there are logs, then you can archive or delete them from System > Archiving. Before deleting a process you could choose to export a copy for back up.
Alternatively you could create a Trash folder or retire old processes from System > Processes > Management.
