Process to check if there are documents for Class Verification
John_GilbertDu1
Can someone recommend on what approach can we do to check if there are documents waiting for Class Verification?
We are using the process "Decipher - 02 Batches to Verify" that came from Decipher BP release to check if there are items for Data Verification and notify the Document SME, but this doesn't work if there are document waiting for Class Verification.
Hi, John,
it is supposed that  you perform class verification only for the beginning with several documents and then you can turn the manual Class Verification off. It is done in the system settings with the slider. If you have mapping between batch and document type 1to1 then you don't need Class Verification step at all. So turn the slider to off and your documents will go straight to Data Verification.
Zdenek
ramonnunez
You can also turn off classification of a batch type by choosing disable on the classification mode. See Classification mode section in the link below:
Decipher Online Gudie - Batch Type: Classification Mode
