Hi, John,
it is supposed that you perform class verification only for the beginning with several documents and then you can turn the manual Class Verification off. It is done in the system settings with the slider. If you have mapping between batch and document type 1to1 then you don't need Class Verification step at all. So turn the slider to off and your documents will go straight to Data Verification.
Zdenek
