Quantity value input- Centrix Data Solutions
Hi All,
while trying to insert a value for Quantity field, this Error occurs
I guess the problem in spying but I don't know how
Sanaa Fallah
Hi Sanna,
In Win32, try spying the entire 'Combo Box' not just the inner section and see if you are getting the below attributes:
This should work properly
Email: [email protected]
Hi Sanna,
Hi Sanaa - that message means 'I can't find any element with the combination of attributes you have selected in App Modeller'. A similar message you will see is 'More than one element matching the query terms', which means 'your combination of attributes are not unique'. Both messages are telling you to rethink your selection of attributes.
John Carter
Professional Services
