how to input text after surface automation being connected to VM
HongJooChoi
Hi, all.
I used surface automation to recognize the input box of an application after having remotely connected to the VM.
I want to put a text into the red box. but when I use Navigate stage I couldn't find a way forward. No "Global Send Keys" function appeared in the navigate stage. Is there any way to fill the box?
Best regards
HongJoo Choi
Hi HongJoo - use the VM 'root' element (or maybe your 'windows_frame2' element) for sending keys. You may need to focus the field by clicking into 'inp_password' first, with a small pause (maybe 0,5s) before sending the keys.
John Carter
Professional Services
John Carter
PabloSarabia
Level 11
Hi!
Just one suggestion... if you want to connect to the SQL Server to execute query o maintenance plans, you can do it with the Business Object "Data - Sql Server". I think is faster than spy the entry application.
Bye :)
Pablo Sarabia
Architect
Altamira Assets Management
Madrid
634726270
Dear John
Thank you, it worked !
HongJoo Choi
Dear Pablo
Thank you much for the reply.
I wanted to test how far surface automation will work for applications running on the VM.
Best regards
HongJoo Choi
