Question on Batch Types and it's functioning
So in Batch Types, we can select multiple Document Types right. Hence if I want to process Invoices, Forms, Contract Notes, etc. various types of documents under a single batch then I can select multiple Document Types in Batch Type settings and process all of them under same hood.
So how does decipher understand which DFD to apply on which document?
Let's assume I have 3 Document Type configured with 3 DFD for Invoices, Forms and Contract notes but from my blue prism process I'm just pushing a single document of Invoice.
So how does decipher know that which DFD it has to apply out of Invoices, Forms and Contract notes?
Thanks & Regards,
Tejaskumar Darji
Ben.Lyons1
Hi Tejaskumar,
This is the function of the classification model.
Where you have a Batch Type with more than one Document Type, you will need to use a Classification Model. This can be trained to correctly identify documents and allocate them to the appropriate document type for processing.
The Document Type will then have the appropriate DFD assigned.
You can read more about Classification in our online help.
Ben
Ben Lyons
Product Consultant
UK
Ben Lyons
SS&C Blue Prism
UK based
