Read Outlook Email Body
MohanV
Dear Experts,
I am trying to read Outlook Email and insert insert into DB table, I am able to load all other fields except Email Body as it's reading as HTML. I tried to use below Regex to handle the issue but no luck.
Output = Regex.Replace(Body, "<[a-zA-Z/].*?> (Text)", String.Empty);
Appreciate if any  advise for any other way handle this issue so that I can get only text portion of Email body.
Note: I am already using the latest VBO for Outl0ok.
Best
Mohan
Soumya21
Hi @MohanV
You can take email body in text also by modifying code
In VBO change the one line of code in internal get items action
in that replace this one line of code row("Body") = If(item.BodyFormat = 2, item.HTMLBody, item.Body) with this row("Body") = item.Body
It will fetch you email body in text.
Soumya​​
Soumya21
Hi @MohanV
Soumya​​
MohanV
Worked like a Charm. Thank you Soumya kalal.
