Retry Mechanism at Object or Process Level
06-07-21 01:40 PM
HI All
Just want to understand, Retry Mechanism should be at object or Process Level.
Vamshi Krishna Dasa
VamshiKrihsna Dasa
System Architect
Fujitsu India Consulting Pvt. Ltd.
Vamshi Krishna Dasa
VamshiKrihsna Dasa
System Architect
VamshiKrihsna Dasa
System Architect
06-07-21 02:11 PM
So, from what I understand Retry must be done at the process level, I have the following definition, My object is dumb (It just does an action such as clicking the login button), since my process is smart and it must decide that if the action of clicking the login button fails, should I try again or not, if I should fire an email informing me, or if I should finish this item and try another one until my queue is full
Emerson Ferreira
Sr Business Analyst
Avanade Brasil
+55 (081) 98886-9544
Emerson Ferreira
Sr Business Analyst
Avanade Brasil
Sr Cons at Avanade Brazil
06-07-21 02:19 PM
In general, retries should be handled by the process. Issues encountered by objects should be bubbled up, and the process should decided how to handle them. Here's the excerpt from the Advanced Exception Handling training on Blue Prism Learning Lounge:
"Most exception handling should be done at process (or component) level. Business objects can
contain exception handling but in general they should be kept as simple, reusable pieces of logic."
