Runtime Resource offline when login
jamesli000
      When my schedule use Login Agent Login the runtime resource, the runtime resource will be offline. I use remote desktop to logoff from RR, RR will change to online.
     If I login runtime resource using remote desktop, RR becomes offline. If I logoff, RR change to online.
     Anybody meets this same issue? Maybe you can give me some idea to solve it.
BR
James
James Li
ManpreetKaur1
Level 8
Hi @James Li,
It seems you have not used a scheduler to schedule the trigger of batch file to activate the resource PC post login/system restart or you can also place the batch file in startup folder to kick off the commands. For ex- in below image, whenever the batch file kicks off, it activates the below window :
Manpreet Kaur
Manager
Deloitte
ManpreetKaur1
Level 8
Hi @James Li,
Manpreet Kaur
Manager
Deloitte
Hello, Manpreet
     Yes, you are great. After I added BAT file, It works. Many thanks for you solution.
BR
James
James Li
Original reference along with screenshot: Turn On Runtime Resource
