SAP Issue
01-11-17 05:24 PM
Hi All,
In SAP I need to spy one element but when I was spying that element in accessibility mode with correct element but when I was clicking on highlighted button it is showing different element
I have matched some attributes but it is not identify element correctly. I have attached my attributes which I was using.
And also Tab functionality is not working there. So I Need to click the element at correct place ?. I also tried HTML mode, SAP Mode also this modes are not working and please don't tell me that u need to spy in region mode because every time the element will change the position for every login.
If have any solution/ideas guys ?
03-11-17 12:37 PM
Hi Avinash,
the SAP Mode is the best solution to spy a field in SAP. Why it doesn't work in your case? SAP Scripting is disabled? Or are you unable to find requested field with that Mode?
If you are trying to handle SAP GRID, I would say, that you need to use a Code Stage, rather the spying mode, for your activities
Rgrds,
L
