SAP Issue
DHINAGARANASHOK
Hi ,    I am facing an issues realted to SAP system. When my bot got this pop up (attched), its not even getting termiated nor running. Because of that the run status of the will be still on running where its affecting other process schduling because after this process run we have one more process to run after sometime.    So my question if we get some pop up releated the attached one can we able to make bot to termianted . Is ther any option to have global time out so after that bot will be termianted like that.
From 5.0.24 a global time out can be set in Application Modeller. With it, Navigate, Read and Write stages will throw an exception if the target application does not respond within the defined time.
