John/Bastiaan,
Thanks for the quick response.
@Bastiaan - the screenshot should be under File: (Capture.PNG) and the SAP application is on a local machine.
@John - there's not a problem with the username and password. The issue I'm facing is with the system connection parameter logon, but I will try and give Global Send Keys a go instead of the Write stage.
Thank you.
Johnny
