Hi Manas,
If you can execute the same select statement directly on a SQL Server query window successfully. It may be that OLE DB doesn't like the way some of those special characters (hyphen, periods, slashes, underscore) are being passed in. Try making a copy of the table for testing purposes and rename it taking out all those characters, then execute your statement from BP adding them back in to the name, one at the time, to see where you get an error. At that point you'll just focus on how to format that character so that OLE DB and Blue Prism can execute it correctly.
That is an interesting table name though!
Jorge Barajas
Senior Product Consultant
Austin, Texas
	Jorge Barajas
Austin, Texas
