Save As screens interaction with Code Stage
xlxu001
Hello, we are trying to build a VB script that would go inside a Code Stage that can interact with any of the 'Save As' screens that show up when you select Save As in any application.  We currently have it working by GSK and adding filepath and filename together and pressing Save, but to ensure it works we had to put several waits and sleeps to make it slow down and it is adding about 20 seconds to each use case.  We did some code stages to interact with SAP and in some areas it significantly decreased the time so just wondering if the same can be done with these Windows dialog boxes and if any help can be provided as to what the Syntax needs to be inside that re-usable code stage.
Lourdes Urena Sr Solutions Engineering Grainger Panama Services Panama
