Hi Vrat,
I'm afraid there's not much you can do about that via the process. When you select the option to open and save, it will save to the default downloads folder.
However, if you update the downloads folder location in the browser settings, it should save it where you need. The challenge you may have is it will do this for all processes using that particular Windows user.
You could just open it without saving, but that will open the document as uneditable and that may affect your ability to attach to it and save using other methods.
Ben Lyons
Product Consultant
UK
Ben Lyons
SS&C Blue Prism
UK based
