Scheduler - Login Agent Not Logging in (Object reference not set to an instance of the object)
MattDavis
Hello, I'm having an interesting problem. My login agent command to login works just fine when I manually execute it against any given resource. However, when it's executed through the scheduler I get an error "Task: Login threw an exception: Object reference not set to an instance of an object." Any ideas why this would only happen when ran through scheduler?   Thanks,
IvetteOnay
hi, do you find the answer?
RayannYassine
i am having the same problem. When I execute it from the scheduler it is saying that the VDI is offline.
RayannYassine
JereVekka
As we have seen this problem but Blue Prism has not been able to provide solution to this, just restart the machine as a workaround.
