Scheduler doesn't start pending items
l.kiciak
Hi, from time to time we are faceing with the problem, when the scheduler adds a new pending item to the session management, but does't run it. The issue is quiet critical, because some of our processes run at night and scheduler blocks VDI pool, and next process cannot be started. Does any of you have had a similiar issue and maybe found a solution or any notifcation system about this kind of situation? Many thanks in advance, Best, L
11 REPLIES 11
MathieuBelin
Reading this post and look like there is a fix on the version 6.3.2   https://portal.blueprism.com/forums/technical-queries/general/scheduler…   Kind regards
AmiBarrett
Level 12
@mathieu - That thread seems to refer to a case where resources are no longer available, which should be separate from the ""stuck in pending"" bug. That being said, I found the following in the 6.4 release notes. Not sure if it means they've fixed it or not.   A further improvement in this area reduces the time taken to retrieve items from a queue based on Item Key filters. • Schedules - Queries on schedules have been optimized to improve performance in the following areas:      • Schedule triggers      • Schedule log entries      • Task sessions
