Scheduler issue - Stops after one task
MathildeBouvet
Hi, I have the following issue with the scheduler. The robot is supposed to follow this sequence of tasks ==> login, wait for login, start the process, logout. It used to work (more or less). But since a few days, it stops after the "wait for login" (via Tight VNC however, I saw that the login was successful). The next step is not performed at all. This is very annoying because the aim is to create a loop because the process needs to run endlessly. Does anyone know what could cause this issue? Thanks for your help! PS: I am using version 6.3.0. version of BP. Mathilde
How long is the wait?
