Are you sure you need to scroll in order to work with the right side? If you can use HTML mode for everything, then you should be able to retrieve any values you need. Even clicks will often work if the area isn't actually displayed on screen.
Dave Morris
Cano Ai
Atlanta, GA
Dave Morris
3Ci at Southern Company
Atlanta, GA
