My issue: the company I work for has audited our department and we need to have at least "Errors Only" on stage logging option.
My solution today: export, edit xml, import. This adds up on killing agility we had before auditing started.
My query: Blue Prism has default stage logging option as "Enabled" or "Disabled" depending on the situation (stage type, process level, object level). I would like to know if there is anywhere in Blue Prism where I can select what are these default values for these "listed" situations.
(I also know about selecting stages page by page and selecting whatever option or setting logging level on resource level, but I want to switch ONLY disabled to errors only.)
