Spying List and Span element
RoshiniSyed
I have few elements in my application which are of type List(<LI> ) and it has two span elements inside and all I want is when I click on ,It should navigate to another page(URL will not change).
I created a navigate stage, captured the list element and  set the Action as "Click Center" , but it doesn't worked as expected?
Is there a any way to achieve what I want?
Please find the attached screenshot for your reference.
Roshini Syed
HarpreetKaur
Level 7
Hello Roshini,
Could you try a different spy-mode perhaps? If memory serves me right I think you should be able to use "Press" if you spy the control in UIA mode..
Harpreet Kaur Product Consultant
Hi Roshini
When you say its not working as expected can you tell us what happens when the process does the click? ar there any errors or does the click just simply not work?
Michael ONeil
Technical Lead developer
NTTData
