Hello Kristian,
If I understand correctly, what you want to do is to log into the same machine with different robot user accounts?
If so, you can simply modify the Login process to have an input parameter called "Credential Name" and add a decision stage to determine if a Credential Name is provided. If a Credential Name is provided, it will retrieve the username and password from that Credential Name in the Credential Manager instead of the default one.
In this case, you can create a set of different login credentials in the Credential Manager, then pass their names to the modified Login process to log into Runtime Resources.
I have attached the process shown below, see if it helps.
Jarod Yang
Senior Consultant | BluePrism
