Hi All,
Just a query regarding spying a label.
Within the Academy Revenues & Benefits system, there are headings of fields that appear if something is within this field. So for example, if somebody is Jointly Liable for a Property then the Header 'Joint Liable (1)' will appear, yet if there isn't any Joint Liability, then the Header won't appear.
Now, I've spied this header as both (WIN32) and (AA), and if it is present, then it works fine, however if it isn't present, then it will fall over. I know that it is something to do with the attributes within App Modeller (Invisible, Active etc....) but cannot find the correct combination.... Also, it is as though the Joint Liable (1) header is there but not displaying upon the screen as it writes this to a Data item....
Has anyone any insight on how to basically use an Object to see if this header is present or not and then use this in a Decision stage.....
Cheers
Tom
