Trying to log into site https://www.ing.com.au/securebanking/ which uses buttons that are visibly different but have no spyable unique attributes and locations. So I'm using regions. Browser is Chrome, the bank is too hip for IE.
I'm using settings as per attachment. Buttons highlight until they move and then I get "Error - Highlighting results - Cannot find region identified as an image."
So it looks a lot like I'm setting the Positionto Anywhere (as per attached pic) but the Position acts as if it is Fixedwith no Search Padding.
I've used regions a lot in the past so am I missing something basic (most likely) or is a known issue?
------------------------------ Matt Cortez ------------------------------
Hi Matt - don't go too wild with tolerance. It's intended for situations where there are slight discrepancies between modelled colours and the run time colours. If the tolerance is too high there's a risk of getting a false match.
------------------------------ John Carter Professional Services Blue Prism ------------------------------
