On the
Developer Jumpstart page on the Blue Prism Portal is where you'll find some process templates. Process Template 1 is the basic one, and Process Template 2 is the advanced one. If you're new to Blue Prism, you'll want to use the basic one. They're both good enough for designing a process that will go to production.
Dave Morris
Cano Ai
Atlanta, GA
Dave Morris
3Ci at Southern Company
Atlanta, GA
