Trigger Exposed blue prism process using Visual studio
Shiva_Reddy
I am trying to trigger an exposed process using visual studio. I am getting an exception as - The HTTP request is unauthorized with client authentication scheme 'Anonymous'. The authentication header received from the server was 'Basic realm="BluePrism"'.'
Here I am passing the correct credentials
Shiva Reddy
GopalBhaire
Level 10
What are you doing with username password is not clear from the screenshot.  You just need to add the Authentication header with a value of "Basic xxxx" where "xxxx" is the base-64 encoded value of username:password.
Gopal Bhaire
