Trigger a process from a post API call
Pranav
Hi Team,
The use case is to trigger a process by the click of a button on a UI and then perform several steps which include
  • Navigating to a web portal.
  • Reading the data from that portal.
  • Posting back the data to the system from where the process is triggered.
I need to know how I can design such a Blue Prism process and is it possible?
EmersonF
You can expose the process and send a soap request to start it, you can also create an orchestrating process that receives some information such as the name of the process and which resource to use and trigger a command line using AutomateC, or if it is something personalized you can create your own api for that!
Sr Cons at Avanade Brazil
