Two or more processes in schedule - how it will work?
16-10-17 12:43 PM
Hey guys,
I have following schedule:
Schedule;
10:00 - Start process 1
11:00 - Start process 2
Process 1 will be complete at 11:15 - what will hapent to process 2? Will it wait to 11:15 to run, ot will it stop Process 1 in middle of work? Any else possible outcome?
Thanks in advance.
16-10-17 02:37 PM
There is a configuration within the product (look in the product help for info) which is 'If a resrouce is offline, retry after:"" and 'Retry an offline resource a maximum of"".
These default to retrying after 5 seconds and trytring a maximum of 10 times.
However, this feature was created for offline resources (where there might have been a network blip) rather than busy resources. Maybe experiment with it to see if it would work for busy resources also?
I think the better solution would be either:
** Have your sessions as follow on tasks within the same Schedule rather than two seperate Schedules. Task two will start when task one ends - which is far cleaner.
** Or you could have an end time in process one that ensures it does not pick up new work after 10:55. That is no use if all items need to be worked.
17-10-17 02:27 AM
Agree with these: Good suggestion Denis, We recently implemented it.
17-10-17 02:27 AM
** Have your sessions as follow on tasks within the same Schedule rather than two separate Schedules. Task two will start when task one ends - which is far cleaner.
17-10-17 12:04 PM
Please let me know, How process End Time can be accessed?
