20-06-19 05:42 AM
Can anyone help me with connection string to connect excel 2016 using oledb for B6.5 or office 365.
Thanks for your help.
Ronik
Ronik Bahl
RPA leader
EY
07-08-19 07:09 PM
OLEDB Connection
Access Database Engine 2016
The first link has a hyperlink to a download that doesn't work so I have included another one after for the Access Database Engine 2016
Hope this helps!
Andrew Randolph
Analyst
Accenture
America/New_York
20-06-19 06:41 AM
Provider=Microsoft.ACE.OLEDB.16.0;Data Source='C:\Users\gopal\Downloads\Test.xlsx';Extended Properties='Excel 12.0 Xml;HDR=YES;'
Make sure to install AccessDatabaseEngine.
Gopal Bhaire
Analyst
Accenture
20-06-19 06:54 AM
Can you please also tell version of AccessDatabaseEngine
We have ACE12 which is not working.
Ronik
Ronik Bahl
RPA leader
EY
20-06-19 07:39 AM
Try this
https://www.microsoft.com/en-us/download/details.aspx?id=54920
Do a quiet installation of 32-bit if you're running 32-bit Office.
Gopal Bhaire
Analyst
Accenture
20-06-19 08:48 AM
Tried it but there are errors coming, sharing the errors as attachment
Ronik
Ronik Bahl
RPA leader
EY
20-06-19 02:45 PM
https://www.itsupportguides.com/knowledge-base/office-2013/solved-how-to-uninstall-office-15-click-to-run-extensibility-component/
Dave Morris
3Ci @ Southern Company
Atlanta, GA
20-06-19 02:59 PM
Run cmd as admin type in the full file path of access db engine ie c:\download\AccessDatabaseEngine.exe /quiet
The quiet flag will install the component without any errors
Gopal Bhaire
Analyst
Accenture
07-08-19 07:09 PM
OLEDB Connection
Hope this helps!
Andrew Randolph
Analyst
Accenture
America/New_York
28-07-20 02:45 PM
Veasna Koeut
RPA Lead Developer
Accenture
America/New_York
