Unable to connect to office 365/Ms excel 2106 using OLEDB
RonikBahl
Can anyone help me with connection string to connect excel 2016 using oledb for B6.5 or office 365.
Thanks for your help.
Ronik
Ronik Bahl
RPA leader
EY
Best Answers
If this issue still hasn't been resolved there is a PDF on the blue prism portal that explains how to incorporate the OLEDB connection with blue prism and where to properly install here
OLEDB Connection
Access Database Engine 2016
The first link has a hyperlink to a download that doesn't work so I have included another one after for the Access Database Engine 2016
Hope this helps!
Andrew Randolph
Analyst
Accenture
America/New_York
8 REPLIES 8
GopalBhaire
Level 10
Connection string will be
Provider=Microsoft.ACE.OLEDB.16.0;Data Source='C:\Users\gopal\Downloads\Test.xlsx';Extended Properties='Excel 12.0 Xml;HDR=YES;'
Make sure to install AccessDatabaseEngine.
Gopal Bhaire
Analyst
Accenture
Thanks Gopal,
Can you please also tell version of AccessDatabaseEngine
We have ACE12 which is not working.
Ronik
Ronik Bahl
RPA leader
EY
Try this
https://www.microsoft.com/en-us/download/details.aspx?id=54920
Do a quiet installation of 32-bit if you're running 32-bit Office.
Gopal Bhaire
Analyst
Accenture
Hi Gopal,
Tried it but there are errors coming, sharing the errors as attachment
Ronik
Ronik Bahl
RPA leader
EY
This should work for you. I did this recently and I have seen no negative impact on my machine. You basically delete a registry key for Office 16 Click-to-Run Extensibility Component. Before you do this on something other than your personal machine, you may want to verify with someone who knows why this registry key exists in the first place.
https://www.itsupportguides.com/knowledge-base/office-2013/solved-how-to-uninstall-office-15-click-to-run-extensibility-component/
Dave Morris
3Ci @ Southern Company
Atlanta, GA
The quiet installation was meant to avoid this error
Run cmd as admin type in the full file path of access db engine ie c:\download\AccessDatabaseEngine.exe /quiet
The quiet flag will install the component without any errors
Gopal Bhaire
Analyst
Accenture
OLEDB Connection
Hope this helps!
Andrew Randolph
Analyst
Accenture
America/New_York
Look at you now Andrew. Contributing for the great good!
Veasna Koeut
RPA Lead Developer
Accenture
America/New_York
