Unattended Robot from Control Room - Surface Automation, Login Agent error
vinothinfosys
Surface automation is not working if trigger the job from another server, unable to find the elements spied via region mode, it runs fine only if im connected to it in my machine. I tried to login to the resource pc via login agent:login  function but getting "Operation timeout error". I just need to run the code unattended (50% is region mode spied).
Thanks in advance
gowdamadhu
Same issue is discussed in the below link
Unattended Mode | Blue Prism Product
EVIPUTI
Looks to me like additional Logon Texts are enabled on your machine and login agent is not able to bypass logon . Can you get this checked from common registry setting ?
