Using Box API with BP
SarthakMukherje
I am trying to use Box APIs (https://developer.box.com/reference/) for a project. From what I understand I need to have an access token to gain access to the Box account using the APIs.
I need help generating and retrieving this Box access token using Blue Prism.
Anybody having experience with similar scenarios or anybody who have used Box APIs in their projects, it would be great if you can help me out on this.
Sarthak Mukherjee
PA
Cognizant
Hi Sarthak,
Looking at this page from the API reference guide it appears that you can request an access token from Blue Prism and the returned JSON response from the Box server will contain the access token (look at the response example in that page). Try setting up a Web API Services definition for Box in your Blue Prism settings page, following this guide:
https://portal.blueprism.com/system/files/documents/v6.4%20User%20Guide%20-%20Web%20APIs_2.pdf
Jorge Barajas
Senior Product Consultant
Austin, Texas
Jorge Barajas Blue Prism Senior Product Consultant Austin, Texas
cvmac
Hi @Sarthak Mukherjee - I am facing a similar issue progressing with BOX API connections in Blue Prism, have you had any luck progressing?​
Chloe MacIntosh
Automation Developer
Zurich Insurance
