Using Capture 4.0 to record blue prism process
lsfossatti
Hi guys,
Does anyone know if it's possible to use Capture to record what's on the screen while blue prism is running a process ? I tried that and Capture only took a screenshot of the clicks I manually performed.
Thanks.
Leonardo Fossattil
Hi Leonardo,
Thanks for your contribution to the community.
Although Capture is not designed for this use case, it should be able to record normal interactions. Are you trying this with the process running at robotic speed or in debug mode with normal debug speed? Sometimes the memory consumption can cause capture to miss on steps.
Thank you,
Omid
Omid Hosseinitabar
Senior Product Manager
SS&C | Blue Prism
London
if robot is doing backend interaction with application that are not foreground, i don't think so capture will pick those. but again then this is not candidate for Capture as Omid Hosseinitabar said.
Neeraj Kumar
