08-04-21 03:00 PM
I am attempting to write a script to be triggered by Windows Task Scheduler to archive our Blue Prism session logs.
I have read through the posts on this community board as well as the knowledgebase articles and documentation on the commandline and know how to do this in a single environment setup, what I'm not clear on is how to specify which environment (or database) that I wish to run the archive task for when working in a multi-environment setup.
Our exact setup is that we have both a development and test environment setup on the same application server and using the same database server (but separate databases). The client on my machine is set to be able to connect to both environments using Single Sign On.
If I run the script (either on my machine or on the server), how can I specify which environment should be archived? Or does the archiving action run on all environments at the same time?
Felix Oehl
Belgium
Felix Oehl
Belgium
09-04-21 09:49 AM
Hi Felix you can use the /dbconname switch to tell the batch file which connection to use. By default the command line will use the current connection but you can override that, eg /dbconname "My Dev Connection"
John Carter
Professional Services
John Carter
09-04-21 09:49 AM
John Carter
John Carter
20-04-21 09:37 AM
Thanks John, that's just what I needed. It would be good if this could be made clear in the documentation.
Felix Oehl
Belgium
Felix Oehl
Belgium
