02-10-23 07:29 AM
Hi All,
02-10-23 02:23 PM
Hi Amrutha Sivarajan,
Both interact and power apps will able to achieve it.
If interact is available to your org, I would suggest to use interact rather than power apps. But both will wok, its just matter of preference.
Note: I have never tried integrating power Apps with BP, but based on my understanding it is doable.
03-10-23 01:20 AM
Hello Amrutha Sivarajan ,,
Regarding integration, it is possible to integrate with most power platform tools (power apps, power automate, etc.), what I suggest is to create a custom connector on the PP, and consume the resource via blue prism, this would be the most flexible way in my view.
https://learn.microsoft.com/en-us/connectors/custom-connectors/
Regards.
Leonardo Soares
RPA Developer Tech Leader
Bridge Consulting
América/Brazil
03-10-23 08:18 AM
To add you can also look at Blue Prism Desktop for attended automation needs.
03-10-23 02:04 PM
Hi Amrutha,
You could send an email to the requester to approve/reject, check the inbox for a response using a keyword lookup and defer any items waiting for a response. We achieved something similar using a 2-step process on a schedule, not as ideal as using MS but works nevertheless.
