Visma Control
14-05-19 08:06 PM
Does anyone have experience with working with the application Visma Control? I can't spy anything in the application unless I use regions. Any suggestions?Â
21-05-19 02:38 PM
Not been using that exact software, but if i remember correctly other Visma software starts an internal launcher when starting the exe file, which again launched the software you actually want to start. We solved this by attaching to the "login application" then again attach to the actual application after it was loaded.
Again, this might not be the case with Visma Control, but worth to check atleast.
21-05-19 09:53 PM
Agreed, if Visma is one of these applications that spawns additional exes, then BP won't be automatically attached to them. Instead you'll need to launch and then attach, maybe by using separate business objects.
20-04-20 09:36 PM
Hi Toseef, did you end up using region to spy Visma or find an alternative solution?
PeterLacken
Ren Røros Intelligent Automation
Peter.Lacken@rria.no
http://www.rria.no
PeterLacken
http://www.rria.no
