When is the right time to create and turn on ML model?
20-11-21 03:42 PM
What is the right time to create and turn on ML model?
Right now I create and add ML model along with Document Type, once I'm done with a basic draft of DFD.
I checked the best practice guide but I do not have 1000 documents at present so does that mean using the ML model will not make any sense or how it works for less than 1000 docs.
Can someone please shed some light?
Thanks & Regards,
Tejaskumar Darji
Thanks & Regards,
Tejaskumar Darji
22-11-21 08:42 AM
Hi Tejaskumar,
I would recommend reviewing the Best Practice guidance and if you have any follow up question, please let me know.
Ben Lyons
Product Consultant
UK
Ben Lyons
Product Consultant
UK
Ben Lyons
SS&C Blue Prism
UK based
SS&C Blue Prism
UK based
22-11-21 03:00 PM
Hi Tejaskumar.
ML is supplemental to a solid rules-based training set up. It will enhance and improve Decipher over time but it will not make a poorly trained rules-based model a good one.
If you don't have the volume, ML will not help.
jack
Jack Look
Sr Product Consultant
jack
Jack Look
