automate applications in remote desktops
07-11-17 05:05 PM
Hi All,
Can any of you let me know if we can automate a windows or web based or putty that runs in a remote machine that is accessed via another remote machine. Yes we can do it using surface automation techniques but is it really possible . Has anyone tried this ?
warm regards,
Amith
07-11-17 07:35 PM
I have a couple of clients that have done just what you suggest, I created the 'Surface Automation of Terminal Emulators' training based upon that experience which is worth a read. It is not ideal but it is certainly possible.
Interfacing with applications running within a virtual machine environment (i.e. running in a VDI like Citrix XenDesktop rather than virutalised as an application like XenApp) is probably the most difficult think to do. Effectively the entire desktop is a Surface Automation application and work needs to be done to build interfaces to do the simple stuff (switch between apps, start apps, etc). Everything you do needs to be based upon image locations.
If possible I also recommed using Blue Prism v6 where there have been some significant improvements to Surface Automation.
