Yes. We can have multiple processes running at the same time on same bot if both the processes are running in background mode or one foreground & one background.
SaiKrishnaThota is correct. Provided the Run Modes of all objects are in agreement, then a resource can run parallel processes. Note however this does not reduce license usage.
