cosuming webservice using blueprism code stage
HEMA__KAMMILI
we are consuming thirdparty webservice using blueprism code stage. we are getting an error when wsdl file is  loading in wsdl.exe but when we are consuming same wsdl file with visual studio we are not getting any error. when we are adding the same wsdl file with blueprism webservice it is adding . There is no problem with the wsdl. Below is screenshot of the error . can you please provide the solution.
Is there a reason you are creating a bespoke web service interface from scratch rather than the SOAP interface built into Blue Prism or the JSON/HTTP objects we provide as the basis for using a REST web service?
