ftp
begum_atalay
Hello, Is there a way to get files via ftp or or sftp in a specific object? I could not find any specific information on the portal. Thank you, kind regards.
7 REPLIES 7
begum_atalay
Hello, Thank you for your reply, so I understand that a code stage should be used for this configuration. Do you have a sample code for downloading a file from SFTP or FTP?
TienNguyen1
void DownLoadFTP() { SessionOptions sessionOptions = new SessionOptions { Protocol = Protocol.Ftp, HostName = "xxxx", PortNumber = 21, UserName = @"xxx", Password = "xxx", }; using (Session session = new Session()) { // Connect session.Open(sessionOptions); string remotePath = "/Test/",localPath = "D:\\2\\; TransferOptions ops = new TransferOptions(); ops.TransferMode = TransferMode.Automatic; TransferOperationResult rst = session.GetFiles(remotePath, localPath, false,ops); session.Close(); // Your code } }
Carol.Ouellet
I have managed to install it and use it but it was more complicated than I expected. Here are the details: 1. Download of Winscpnet assembly: https://winscp.net/eng/download.php 2. Created an installation file using InnoSetup including WinSCPnet.exe and WinSCPnet.dll to install in C:\Program Files (x86)\WinSCP (Could be anywhere else as long as all resources use the same path) 3. In the InnoSetup it is important to specify that we want winscpnet.dll to be added to the Global Assembly Cache (GAC). My [File] section looks like below: [Files] Source: ""C:\Program Files (x86)\WinSCP\WinSCP.exe""; DestDir: ""{app}""; Flags: ignoreversion Source: ""C:\Program Files (x86)\WinSCP\WinSCPnet.dll""; DestDir: ""{app}""; StrongAssemblyName: ""WinSCPnet, Version=1.3.7.7333, Culture=neutral, PublicKeyToken=2271ec4a3c56d0bf, ProcessorArchitecture=MSIL""; Flags: ignoreversion gacinstall uninsnosharedfileprompt 4. You must restart Blueprism in order to recognize the modified GAC If you downloaded a different version than 1.3.7.7333, you must get it's PublicKeyToken. 1. Start the Developer Command Prompt for Visual Studio 2. Go to the DLL folder and type in ""sn –T winscpnet.dll"" If you can't bother with any of the above, I have put the install file on my OneDrive account. https://1drv.ms/u/s!AlJUlmssD6dC70qrWjaPqQXBzzRn Hope this helps.
NevilleWatson
Are posts missing from this thread?  It doesn't seem to flow logically.
Carol.Ouellet
Yes some posts are missing. I can't remember the whole conversation but I know I found installing the free winscp assemblies was the way to go for me to use SFTP. If you go FTP only, then .Net would be simpler to use in a code stage.
NevilleWatson
I have designed an object to operate FileZilla
jayakishanbodd1
Can share that object here @ Neville.watson
