how to get coordinate of a web element
ManojPatidar
Hi everyone,
I am trying to capture screenshot of a web element of a web page.
i got logic for how to capture screenshot but stuck with how to get the coordinates of the web element.
If anyone have any idea or worked with same. Please let me know
Manoj Patidar
11 REPLIES 11
Hi Manoj, Looks like you are looking for screenshot VBO?
if so check below threads for screenshot VBO
https://community.blueprism.com/viewdocument/re-screenshot-vbo?CommunityKey=1e516cfe-4d1f-4de9-a9eb-58d15bf38c81&tab=librarydocuments
https://community.blueprism.com/communities/community-home/digestviewer/view-question?ContributedContentKey=d3e9064b-6cd3-4846-99ac-9ea618946547&CommunityKey=1e516cfe-4d1f-4de9-a9eb-58d15bf38c81
Harish Mogulluri
Lead developer
America/New_York TX
Harish Mogulluri
Hi Harish,
Thanks for your time and effort.
I want to capture screenshot and I got logic for that but the coordinates passed into the code are static and I want to capture  a particular div tag of a web page.
don't know how to do that.
If you know anything please let me know.
Manoj Patidar
Babjee24
Level 7
Hi Manoj,
If you're looking for the co-ordinates of an HTML element then using a reader stage you can use the property get screen bounds which gives the co-ordinates of the HTML element attaching the screenshot for your reference
Babjee Vangipurapu
Senior RPA Developer
Wonderbotz
India
Babjee Vangipurapu
India
Hi Babjee,
Hope you are doing great.
I used Read stage and I am getting relative coordinates to the web page but not relative to the window size, so when I am trying to use them to capture screenshot I am getting image of other part.
While to suggest something for this, on how to get coordinates relative to windows instead of webpage.
Thanks and Regards
Manoj Patidar
Manoj Patidar
Hi Manoj,
As part of the best practice you can use maximize window after launch for the browser and then try getting the co-ordinates. Please let me know if you're still unable to get the correct co-ordinates.
Babjee Vangipurapu
Wonderbotz
India
Babjee Vangipurapu
India
HI Babjee,
can you help me with how to maximize the browser window. I am using type of application as browser based application in application modeller. I used global send key event where i am passing "{F11}" in text field in input.
Thanks and Regards.
Manoj Patidar
Hi Manoj,
You can spy whole window in win 32 mode in app modeller and then you can see maximize action in  navigation stage.
Harish Mogulluri
Lead developer
America/New_York TX
Harish Mogulluri
Hi Manoj,
As suggested by Harish switch to Win32 mode resize the browser window, spy the entire chrome window as shown in the below screenshot
Then using the element you'll get the Maximise option as shown below
Hope this helps...
Babjee Vangipurapu
Wonderbotz
India
Babjee Vangipurapu
India
@ManojPatidar
You can try this command after the URL --force-renderer-accessibility --start-maximized so that screen will be maximised automatically.
[URL] --force-renderer-accessibility --start-maximized
SYED FAHEEM
DAR-ME
RPA Lead
