not able to send mail using VBO SMTP/POP3
08-01-19 08:26 AM
I am not able to send message through mail by importing mail VBO . Getting the error as "Internal : Could not execute code stage because exception thrown by code stage: The remote certificate is invalid according to the validation procedure."
Can somebody help me please!!
5 REPLIES 5
08-01-19 09:09 AM
From suggestions post I tried, disabling anti virus and firewall and then sending messages, that too didn't help!!!
08-01-19 10:53 PM
It sounds more like the certificate last downloaded by Outlook has become invalid. Generally, if you launch Outlook and it thinks it needs an updated cert, it will bring up a confirmation window.
It may also be a problem with the configuration of the actual exchange server. Are you able to send/receive manually?
08-01-19 11:19 PM
I am currently using gmail for this not Outlook, and I am able to send/receive manually in Gmail. How to check the cert whether it has expired or not?
what can be done to send the mail successfully?
08-01-19 11:33 PM
You can either try to modify the code stages to disable encryption (Note: This is not recommended for production), or you can try to re-install the cert via IE, then ensure it's set up properly via MMC.
Check here for more info: https://blogs.msdn.microsoft.com/jpsanders/2009/09/16/troubleshooting-a…
12-01-19 12:27 PM
ok, I ll check
