object does not work in process studio,
30-08-18 10:50 AM
automation is running when run from object studio, but where as the same object is called from process studio which is not running. I tried using wait stage and conditional wait in object studio but no help.
31-08-18 09:14 AM
can any one help me on this.
Thanks.
31-08-18 10:04 AM
Hi Suresh,
Can you share the error details?
Ranjeet
31-08-18 05:42 PM
Check references within objects, as if there's any to non existing objects, it will definitely fail. Debug mode allows this, but proper scheduler - not.
Basically - check if there's no obvious errors.
