process is not running from control room
When we are trying to run the process from control room,we are not able to run that process it is showing error like-"INBASDPC11388 is too busy to run that process." we are getting "pending status" under session info tab.
Before posting to the forum always go to the Knowledgebase and do a search.  If you search there for 'too busy to run that process' you will find a result that explains what you are seeing. Your resource is busy - which means it is already in use.  In control room change the start time filter from Today to All - 99% of the time when someone raises this it is because there is an old Pending session sat there from a previous day.
