13-07-18 06:21 PM
Hello All,
I am working on web-based java application to copy the data and paste it to excel. i am facing issue with the application sometime the application freezes due to which bp also freeze. if we close the ie window BP starts working in normal mode.
i also tried to use Application manager mode as External 32 bit with wait time as 3 min however its the same it does not throw any exception.
kindly find the attached application modeller screenshot.
Please let me know how to solve it.
Sachin Bais
02-09-20 08:00 PM
Hi Sachin
A couple of suggestions:
Please make sure you have installed the up to date JAB, if your current version is out dated already. Make sure it is error-free during your installation process.
In Joe Khor
Sr. Product Consultant
There is an article in the Blue Prism knowledge base about installing the JAB files manually: https://blueprism.knowledgeowl.com/help/manual-jab-installation
You may also want to read the Java Automation Guide that contains hints and tips when interfacing with Java applications.
Here is the Java bridge Access pdf: https://portal.blueprism.com/system/files/2017-11/v6 User Guide - Java Access Bridge.pdf
In Joe Khor
In Joe Khor
02-09-20 08:00 PM
Hi Sachin
In Joe Khor
In Joe Khor
In Joe Khor
